2 Diagrammen
Populaire forumvragen
Stel een vraagEr zijn geen vragen. Wees de eerste om een vraag te stellen!
Modellen
BTFP02006
Background
The Bostitch Air Compressor BTFP02006 is a portable air compressor suitable for tasks such as inflating tires, powering pneumatic tools, and other light-duty applications. It is manufactured by Bostitch and is designed for home use.
The BTFP02006 is a 6-gallon pancake-style air compressor equipped with an oil-free pump, which eliminates the need for regular maintenance. The pump can generate a maximum pressure of 150 PSI and delivers 2.6 SCFM at 90 PSI. The air compressor is designed with a high-flow regulator and a quick-connect coupler for easy connection of air tools. It also features a control panel with an on/off switch and a pressure gauge. The unit weighs 29 pounds and requires a 120V electrical outlet for operation.
Technical Specifications
- Model Number: BTFP02006
- Product Type: Air Compressor
- Tank size: 6 gallons
- Pump type: Oil-free
- Max pressure: 150 PSI
- CFM at 90 PSI: 2.6
- Amp draw: 15 Amps
- Power source: 120V electrical outlet
- Power cord length: 6 ft
- Dimensions: 18 x 18 x 19 inches
- Weight: 29 pounds
Warranty
The Bostitch Air Compressor BTFP02006 comes with a 1-year limited warranty. This warranty covers defects in the materials and workmanship of the product. However, it's important to note that the warranty does not cover normal wear and tear, misuse, or accidental damage. In order to claim this warranty, the original purchaser will need to provide a proof of purchase. For any warranty claims or support, users should get in touch with Bostitch customer service.
