Battery
Geen antwoorden 0 Score |
Which way around do the leads fit on top of the motor. |
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Troubleshooting
For more information concerning common problems with the device, check out the link below.
Background and Information
This Black and Decker Pivot Vac is an 18V cordless handheld vacuum. the model number that should be on your device should be PHV1810.
It has an easy to empty dust collection chamber.
Some known failures of this device are the motor, the battery, and the charging port.
The user should be able to easily complete these repairs with little to no problem from the device.
Additional Information
Here are some links to identify that you have the Hand Vacuum that is identified
Black and Decker PHV1810 Troubleshooting
