lcd not getting on properly?
LCD light just blink then stand by mode. what i will do?
Is dit een goede vraag?
anaz, sounds like a power problem to me. Check for damage to the AC adapter or Cradle (including dirty or damaged connectors/contacts). Check your battery and your contacts for proper voltage when plugged in. Check that it is properly seated. Check your cable to make sure it is working okay. Check the ribbon cables to your LCD, make sure that they are okay. You also have 2 fuses on your device. One is for the charging circuit and one is for the power circuit. In that case, your device would turn on with a properly charged battery, but it will not charge. So again, check that with a multimeter. Hope this helps to get you started.
Was dit antwoord nuttig?
i fix already that 2 fuses. and the battery it is charging properly. but the problem when i am pressing the power button lcd just light on with white screen then suddenly shutting off. before this i changed the cartridge slot then it showing the problem. pls help me!!!
Did you make sure that both your LCD's are working? It will shut off if your cables are not properly connected or the display is not working. Why did you change all those things? Both fuses and the cartridge slot? How did you fix the fuses?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 442
