Can I insert 16Gb RAM into MacBook Pro early 2011?
Apple says that I can upgrade my RAM from 4GB to 8GB (2x4GB RAMs). Is it possible to install 2x8GB DDR3 SoDIMM 1333MHz cards into my Mac?
I went ahead and installed 16GB RAM ram in my Macbook. It works fine, except for when I try to run Windows 7 Pro in bootcamp. It comes to the login screen then it stops. sometimes it just comes to a white screen. I think win pro7 can handle 192 GB REM, so what's the problem? Can it be the memory model ? I bought Crucial DDR3 16GB 1333MHz SODIMM for Mac.
Thanks!
Is dit een goede vraag?
13 opmerkingen
Sorry to be digging up old posts, but i am wanting to upgrade my mbp to 16 gb and want to know if all the ram will be recognised.
I have searched the web to the ammoumt i am capable of and can find a clear answer anwhere .
Thanks
door Tekone
Hey guys, I have an early 2011 15 inch Macbook pro and I've upgraded it to 8Gb ram (2x4Gb RAM's). Apple says "4GB (two 2GB SO-DIMMs) of 1333MHz DDR3 memory; two SO-DIMM slots support up to 8GB" from this link:
http://support.apple.com/kb/sp620
Is it possible to upgrade from 8 to 16Gb?
I know this post has been answered and have said 'yes we can upgrade to 16gb', not so in those words but you get it. I just wanted to make sure.
Thanks.
Arjun
door Arjun
Arjun - For future reference you posted a Question in the place where only Answers belong. Please use the add comment link to the appropriate Answer or Start your O.Q.. All 011 models can run 16GB RAM it is not supported buy Apple, but, it works.
door originalmachead
Hey I added 16 gigs to my early 2011 MacBook Pro and did it ever-increasing performance. It was a slug till I changed over the ram.
I'm sure you can get a lot of extra speed with a SSD but why spend the money when you can improve the speed for fraction of the cost. Every time that I upgrade the OS the system seemed to slow down. It was placing so much into high memory on the ram that my machine was almost useless. Now the speed is right where I like it to be and I don't have any problems with it all. Even the old problem of it searching the Wi-Fi every five seconds really is not problem. I bought the memory on Amazon and it was cheap and you can check on YouTube for instructions on how to replace it in your machine.
My MacBook Pro and my iMac both have 16 gigs and the old iMac is a I5 and the MacBook Pro is a I7.
Try the memory first it's cheap and then decide whether you want a SSD. You may discover that the SSD is not needed.
Good luck and happy repairs
door miata90redd
I also added 16 ram to my early 2011 MacBook Pro and a 500 SSD drive.. $300 for everything.. Brand new computer.. Very easy to do it yourself also.. tons of videos on You Tube.. Highly recommend doing both...
door Classic Sports
8 commentaren meer tonen
