Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
iPhone does not charge or detect by pc
hi
please help me , my iphone 3gs does not charing or detecting in pc ... but when the iphone is turned off or low battery it detect the charge and charge normally ...
i cant restore it because when it is in dfu mode it does not detect by PC. please help help help........
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
So when the phone is off, or the battery is below a certain point, iTunes recognizes it?
Make sure you are entering DFU mode, not recovery mode. Here is how to enter DFU mode:
1. Hold down the power and home buttons for ten seconds, or until the phone shuts off. The phone shutting off is what you want to happen. If its already off, turn it on, or begin the boot process.
2. Once it shuts off, let off the power button and hold the home button until iTunes sees it. If you have to do this longer than 60 seconds, then you failed step 1. If you can't get it, repeat until you are in DFU mode.
Was dit antwoord nuttig?
Voeg je antwoord toe
abderraouf2008 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 3,244
