My phone didn't charge..and it's not fall down or wet
My phone didn't charge..even it didn't Fall down or wet
Is dit een goede vraag?
@hezel start with the basics. First, check your charger to ensure it has the proper power output, and inspect your charging cable to make sure the connectors are not bent or damaged. Next, check the phone's charging port itself. Clean out any dust or debris with a few puffs of air to clear it completely.
If those basic steps do not work, plug in a USB ammeter to see if your phone is drawing any amperage from the charger. If it is not drawing power, you are likely dealing with a bad charging port, a disconnected internal cable, or a dead battery.
To narrow the problem down, you will need to open the phone and use a multimeter. Measure the voltage at the battery connector, then plug the charger in and measure it again. The voltage should increase. If it doesn't, the power is not making it past the port and charging circuit.
At this stage, you need to inspect the internals. Check teh main flex cable that connects the charging sub-board to the main motherboard for micro-tears or corrosion, and make sure it is properly seated on both boards.
If all the connections are secure and the cables look intact, I suggest starting with a new battery and the charging board.
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 28
Altijd: 42
