How can I check if a ROG MAXIMUS XI GENE Motherboard is damaged?.
These are the issues I experienced with my PC, as well as the damage I may have caused:
  • When I typed very quickly, my keyboard sometimes failed to register certain symbols or activate some of its functions. During these instances, the PC occasionally beeped, with a short pause between beeps.
  • When I moved the mouse very quickly while using several of its functions at the same time, it sometimes failed to respond properly. The cursor would stop moving, and the PC would occasionally beep, with a short pause between beeps.
  • Sometimes the PC turned on but failed to boot the operating system. On those occasions, I believe the red diagnostic display on the motherboard showed A0, although I am not certain.
  • The PC sometimes failed to boot when one or more USB devices were connected.
  • The PC also sometimes failed to shut down when one or more USB devices were connected.
  • I occasionally hit the PC with my foot and punched it. Sometimes the kick and punches occurred at the same time, and sometimes they occurred separately. The motherboard’s red diagnostic display appeared to show A8, although I am not certain.
  • When the PC failed to boot because one or more USB devices were connected, the diagnostic display appeared to show A6, although I am not certain. The same code appeared when the PC failed to shut down with USB devices connected.
  • I configured the storage controller for RAID using SATA connections, enabled SuperSpeed, and set the storage configuration to RAID 0. The array consisted of a 1 TB internal SATA III hard drive and a 256 GB internal SATA III SSD.
  • After configuring the RAID array, I performed a forced shutdown. I also performed forced shutdowns whenever the PC froze, failed to shut down, or failed to boot, including when no external storage devices were connected.
These are the issues I experienced with my PC and the actions that may have caused damage to it.
Is dit een goede vraag?
1 Opmerking:
I don’t remember all the issues my PC had or all the damage I may have caused to it.
door Deel
Voeg een opmerking toe
