Anyone stating alternator failure is causing a crank, no start issue, isn't familiar with EFI systems, period. Alternators output only when the engine is cranking and running; to supply power to vehicle electrical systems while recharging the battery. Alternators do not prevent engine starting. The battery is the main power supply for powering the entire EFI system and power for the starter. The battery must be in good condition (engine cranks fine?) for the starter and EFI system to operate the engine.
EFI systems relies on three things; air, fuel and spark. Presuming the intake air system isn't choked from a clogged air filter, a few things should be checked; fuel pressure, injector operation, and spark. This presumes mechanical timing and engine compression are ok otherwise they should be checked. One way to narrow a problem down would be removing spark plugs for examination. After several engine starts without the engine ever firing up. spark plugs should be soaking wet from cold engine/rich fuel mixtures. Plugs should be wreaking of fuel. If fuel isn't present, the fuel pump and/or injectors are suspect. Check fuel pump pressures; at ignition on time, the fuel pump should run for a few seconds then shut down, enough time to build up pressure and measured with a pressure gauge. If pressure (35-75 psi) is good, injector operation may be suspect. Keep this in mind while continuing with troubleshooting. There should be one main injector fuse powering all injectors. Next is checking for spark.
With plugs removed, reconnect plugs wires or ignition coils and ground plug bases to engine block. Test for spark by running the starter as spark should be occurring while starting. Failure of spark may be either a fuse issue or related to lack of fuel on spark plugs. Injectors and spark rely on one main sensor, the crank position sensor. It supplies the electronic heart beat to the engine ECM to operate the entire EFI system. A dead crank sensor = zero injector operation, zero spark, and zero fuel pump operation.
