De Dodge Journey is een middelgrote crossover-SUV die sinds modeljaar 2009 wordt geproduceerd en op de markt wordt gebracht door het merk Dodge van FCA, met een kleine facelift voor het modeljaar 2011.
Doorzoek deze discussie om de juiste plek te vinden voor je opmerking. Klik vervolgens op "Link je opmerking aan dit bericht" om je opmerking te verplaatsen.
The antilock brake system may be considered the electronic heart of a two part brake system; the basis hydraulic system (when maintained as needed) and the abs electronics rarely needing service as long as external wiring and wheel sensors are intact. The red brake light indicates; parking brake applied or brake fluid at low level. The abs/traction control/electronic stability control/vehicle dynamic control system is all electronics and performs its own self tests at every engine startup (indicators turn on for lamp test while modules perform power up self tests, turning off when tests pass). Error codes may not appear on generic readers. Better readers capable of decoding B, C, and U codes (generic readers decode P type, emissions errors). Please remember, abs/tc/esc/vdc can fail but will not prevent the basic hydraulic brakes from operating as they always have before enhanced braking (electronics) systems became an addition.
Hi @angelasmit61223
What is the year and drive type i.e. FWD or AWD of the vehicle?
Have you checked if the hydraulic fluid level in the brake fluid reservoir in the engine bay is at the correct level?
door jayeff
door F Dryer
