My car has problem in the electric part
"The EPS light came on in my dashboard. What should I do?"
Is dit een goede vraag?
Score 1
3 opmerkingen:
What year is your Hyundai? Other than major issues like crash damage, lack of periodic maintenance, perhaps this may be as simple as a worn out battery showing less than 12.5vdc, engine off. Ejection power steering relies on steady battery power, battery cables free of corrosion, good connections, drive belt in good condition, belt tensioner, and alternator (14.5vdc, engine idling). Good auto parts stores provide free battery and alternator tests, in or out of the vehicle.
door Deel
"Here is a photo of my dashboard with the EPS light illuminated while the engine is running. As mentioned, the battery indicator is green, but the light stays on."
door Deel
"Ejection" power steering? Spell checker/my bad for not reviewing reply. Electric power steering.
No photo in your reply. Most indicator lights (abs, other than the check engine light means that indicator has a stored error code. EPS on means an error about electric power steering with a code but you must use a reader capable of decoding them.
door Deel
Voeg een opmerking toe
