Why is my car engines have sound
Is dit een goede vraag?
We really need a year, as a lot of these LRs before the LRJ acquisition use the BMW V8 (~2003-2005, BMW M62TU 4.4L V8), which is known for timing chain guide issues which are catastrophic and create the same noises, and the cost often totals it out :-(. Pending a video or something to show the sounds, it might be a BMW timing chain guide issue as a lot of LRs used BMW drivetrains for a while before LRJ took over. The BMW VVTI (VANOS) system is also a known issue as well. If the chain is bad, you will be able to tell by the slack and sometimes you have a few missing pieces from the guides that are visibly cracked that are already lost. If you see brown or orange plastic in the oil filter and the pan, it's a goner.
Even the BMW X SUVs have the same terrible V8s which blow through timing chain guides, so it's just a BMW thing if you have one of those. They always end up in scrapyards because the cost of repair exceeds the value of the vehicle, especially in inspection states like NY, NJ and MD. The same engine and it's later models like the M62 based on the one in those LRs caused similar grief for years in the BMW chassis, so it's known. Inspection states catch them dead in their tracks on a regular basis.
Was dit antwoord nuttig?
Can you please explain? Just saying "my car engine is making a sound" isn't really helpful to us trying to help you fix the problem, all gas engines make sounds. Could you try to explain what type of sound your car is making, or, if possible, an audio recording (NOT a video recording) without any overlay from external environments or speech? Please, if you are absolutely able to, try to better explain the problem whenever you are able to. Please and thank you.
(Also, if you are able to, try to get it to the shop if you don't want to do it yourself. But if you DO want to do the fixing yourself, try to look through iFixit to find the correct guide to help fix your car and get the right tools and parts if needed to fix the car.)
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 38
Altijd: 178
1 Opmerking
If English in not your first language, can you write in your language? Google translate can help you and anyone bridge language barriers.
door F Dryer Deel
