Ga door naar hoofdinhoud
Microsoft's derde generatie Xbox game console, uitgegeven op 22 november 2013.
What could I be doing wrong on my xbox one
Hi i have this old xbox one i'm trying to get working that i'm guessing the power supply went cause it won't power on it just makes a sound no lights so i tried using a standard computer power supply i tried two ones a HP 702304-002 with a weird pin layout and the other was a dell power supply with the standard 4 pin cpu and 24 pin motherboard here's what i did for both note i only have 5 wires for this xbox 2 12v 2 gounds 1 red and 1 blue no gray
i also watched this video showing the blue wire isn't used https://youtu.be/GTd-3Ad-fGU?si=PvITDU9c...
HP P1 connector i used this https://fabozzi.net/installing-normal-at...
2 yellow to 12V cable on xbox
2 ground cable to ground on xbox
P2 connector
i just tried to use pin 2 since that was the closet that was 5V but when connected i used a multimeter and it was only registering about a volt even with the power supply fan spinning
i also tried pin 3 for the five volt also didn't work
Dell power supply
this one i tried putting the 2 12v and the 2 ground into the 4 pin cpu
both i also tried jump starting the fans incase they were not registering it was on as well both the 12V wires were coming up as 12V on a multimeter but even after this i don't even have the sound coming thru like when i tried using my broken original xbox one power supply
update: I now got the 5V wire taking 5V but it still isn't turning on
Update: tried also plugging the red wire into the purple 5V standby on the dell power supply still nothing
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi!
To be honest, I would just replace the original power supply for another one.
You could damage the board with modificated power supply’s.
Maybe something else on the board died, causing no longer to power on.
Would try another original PSU first to be like 100% sure that it’s PSU related.
This saves you a lot of time and testing.
Can you let us know how that goes? Thank you!
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
RobbyThomas2525 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 46
