Hi I’ve got a 2011 R56 JCW
The ring around headlights stays on for 5 minutes after locking car, can the time be adjusted so they go off sooner?. Thanks.
Is dit een goede vraag?
It may not be possible on these, since these often lack the BMW infotainment system (but have the BMW engines and their famous issues like the plastic timing chain guides that degrade due to engine heat and cooling system problems). The upspec model often has the setting (Visual boost), but it's often not found on the basic radio - these often have a basic CD/aux radio and a lot of them bury it under OBD coding or engineering menus.
Give this a shot and see, but you may need the 2nd option below:
If you have an all function (preferably bi) OBD scanner, you can usually code things like this but you need one that explicitly supports BMW coding. Most cheap to midrange bidirectionals aren't reliable there for BMW models, but Autel scanners almost all support it. BimmerCode is also another possible option.
Was dit antwoord nuttig?
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 26
Altijd: 178
