F9E1 whirlpool washer won't drain FIXED
UPDATE: NO POLARITY. CONNECT THE WIRES HOWEVER YOU WANT. Wtw5100hw0 wouldn't drain, so I checked the hose for clogs. Checked the plug for continuity and nothing. I found a break in the wire so I fixed that. Check continuity and nothing, I cut the connector off and both wires have continuity. Now the problem is I can't find the connector I cut off. I have female spade connectors on the wires but have no idea which wire goes to what terminal on the pump.
Is dit een goede vraag?
