Replaced lower case and hard drive, now no power except fans.
I replaced the lower case and hard drive on my MacBook Pro Core Duo (A1150). When I connect the battery, the fans begin to run and don't stop. The power button does nothing and nothing else seems to be active at all. It's like the unit is off, except the fans. It does not do it when I connect the AC adapter, only the battery. And the light on the AC adapter does not turn on. When the battery is not connected, plugging in the AC adapter does not make the fans go on. Did I damage the I/O Board?
Is dit een goede vraag?
2 opmerkingen
Why did you replace the bottom case and hard drive? What was it doing before?
door mayer
I bought it on ebay. The bottom case was beaten up so I just wanted to replace it. As for the HD, I just wanted a larger one. Before I opened it up, it booted fine, charged the battery, the light on the AC adtapter worked and everything was good (except the bent case).
door Robert
