Ga door naar hoofdinhoud
My flap broken and my air conditioner doesn't swing
It cannot swing
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
If the flap is broken and the swing isn’t working, it’s usually either a broken hinge/clip or a faulty swing motor. In many AC units, the flap is controlled by a small motor, and if that motor or its linkage fails, the flap won’t move at all.
If the flap itself is physically damaged, you may need to replace the flap piece or try a temporary fix (like carefully reattaching it). If it’s the motor, then it might require opening the unit and replacing that part.
Also worth checking: try a power reset first—sometimes control issues can stop the swing function.
If you’re not comfortable opening the unit, it’s safer to get a technician to look at it.
Was dit antwoord nuttig?
Voeg je antwoord toe
Kassech Dejene John zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 52
Afgelopen 30 dagen: 183
Altijd: 970
