Hi @calvinalexander
I couldn't find the 2006 GS350 wiring diagram but here's an image of the 2007 GS350 start circuit wiring diagram that may help.
(click on image)
Hi @calvinalexander
Here's the same wiring diagram which I've shown all the major components that are in use and their operate paths when starting the engine . You would need to have a DMM (digital multimeter) to check if the voltage was getting to and through each of the components.
In this case the best way to read the schematic is to work backwards from what the objective is i.e. operate the starter motor as this is what cranks the engine
As can be seen at the bottom of the schematic the battery connects to the starter motor winding, once the starter motor solenoid has been operated.
To get the solenoid to operate you need to have the follow components either operated or in the correct position
Moving up from the solenoid (in the starter motor box) you have the starter relay which needs to be operated and also that the 30A Starter fuse is OK.
To operate the starter relay, you need to have the gear shift in the park (P) position), and the Start Cut Out relay operated.
To get the Start Cut out relay operated you need to have a signal from the PCM (powertrain control module) and the ECM (engine control module) which basically says that everything is OK to start the engine.
To get the signal from the PCM and the ECM the Ignition 2 relay needs to be operated and it is the ignition key that operates the IGN2 relay.
Do the appropriate instrument panel warning lights turn on when the ignition key is turned to the ON position (not Start)?
If they do then most probably the ignition relays are operating but this doesn't mean that the relay contacts are OK
If they don't it could be the ignition key lock or the wiring from the ignition key.
Hopefully I haven't confused you too much
(click on image)
2 opmerkingen
Does it make a clicking sound when trying to start?
door Craftsman fan Deel
No, it doesn't make a clicking sounds. The battery terminals are clean plus the battery is fairly new. But, sometimes the engine will crank for an instance, about two to three seconds, if the battery has been disconnected for a few days. I'm starting to think that the problem may be the starter relay.
door Calvin Alexander Deel
