لماذا لا يعمل محرك السويكلاس
عندي مشكل ماء سويكلاس ماء ما كايطلعوش الموتور خدام ملي كانجرب كانقلعه كانجربه في الباتري يخدم قرعه فيها الماء ملي كانبرك على البطونه اللي في اليد باش تطلع الماء ما كايخدمش الموتور
Is dit een goede vraag?
2 opmerkingen:
مشكله في العزم في السياره
door
**Revising windshield washer problem**
I’m refining the wording for a question about the windshield washer motor. I want to write it clearly in US English. My main issue is the washer fluid not coming out. Although the motor runs when I test it directly on the battery, it doesn't activate when I press the button on the steering column. I think I'll go with "button/lever on the steering column" to keep it concise and clear. Let's produce it now. Why isn't the windshield washer pump working? I have a problem: the washer fluid doesn't come out. The pump runs when I test it — if I remove it and connect it to the battery it works and pumps water — but when I press the button/lever on the steering column to make the fluid spray, the pump doesn't operate.
Did you check for a washer pump fuse? Tried measuring the connections for power when Someone turns on the washer pump from the steering column?
door
Voeg een opmerking toe
