Ga door naar hoofdinhoud
Originally released on January 22, 2005, the Mac mini is a small form-factor desktop computer made by Apple Inc. Currently, it is one of the four desktop models in the Macintosh lineup, and serves mainly as an alternative to the all-in-one iMac.
872 Vragen Bekijk alle
Mini won't boot after replacing primary internal HD
This model has the 2 internal drives instead of 1 optical drive. After reassembling (twice) it won't boot. I get a grey progress bar that makes it about half way across the screen before starting over.
Tried to boot into single user mode but no joy. Tried the option key to boot from the 2nd internal drive but no response. I know the second drive ( backup) was fine when I powered it down.
Any help is appreciated, this need to be back at work in the morning.
Is dit een goede vraag?
Score 1
1 Opmerking
Of course you formatted the new drive and installed an OS?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If you haven't already, boot from your original system installation DVD disk, "C" key. Go to the second screen pull down menu to Utilities > Disk Utility. Select the new drive in the left hand column and format it and give it one partition. Quit Utilities and continue with your system installation.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Clinton zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 537
