Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Vragen Bekijk alle
Vraag afgerond
Gold 2 prong connector. Where does it go?
When I removed the logic board this 2 prong gold connector was laying under it. Not sure where it goes.
Neded some help. Thank You!
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
This part is only on iPhone 4S and iPhone 4 CDMA. It is the ground clip for the back main camera. It goes near top of iPhone above back of camera. The screw hole of this part goes over logic board (on top of logic board as you work on it) and is held in place by logic board screw. The black tape if still present goes over the screw head.
Was dit antwoord nuttig?
Score 2
Can you take a picture of it?
Sometimes a small gold piece falls apart from the EMI shield :
Not replacing it right will cause bad wifi reception
I lost this part while repairing my iPhone 4s. My iPhone still works though. Would this be a problem?
1 Opmerking:
everything will work, no problem...
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 6,151
