Ga door naar hoofdinhoud
Microsoft's derde generatie Xbox game console, uitgegeven op 22 november 2013.
Xbox One front panel works but no sound
As title says. I have replaced the front panel, speaker, and front panel board with other parts that I know work, but there is still no sound. The buttons work like normal.
edit 2: video of whats happening;
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi!
Usually it's the speaker that is broken that is on top of the metal case.
Although, this is the one which is responsible for the sound when you click on a button.
It's connected to the front panel board where the ribbon cable goes in as well.
Then it could be something on the motherboard, but this is very unlikely.. Are you sure that those parts did work before?
Was dit antwoord nuttig?
Score 2
24 opmerkingen:
yes, i have a 2nd xbox that i tested the speaker on (broken disc drive, waiting for a new one) and the speaker worked fine. just to be safe, i swapped all items mentioned above to the 1st xbox and everything works, just no sound
door
That is weird... Then it must be something on the motherboard. Can you find anything that look damaged there?
door
besides 2 capacitors that are slightly tilted, nothing that i can see. Was there anywhere for me to upload pictures for you?
door
Hmm, should be fine. It will be difficult to find the component which is causing this... You can yes > Voeg afbeeldingen toe aan een bestaande vraag
Thank you!
door
added the photos, wish they were next to eachother instead of a massive line.
door
19 commentaren meer tonen
Voeg je antwoord toe
G0d0fninjas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 37
Altijd: 268
