Battery not detected after a new install.
I installed the battery as per the instructions, which went fine... on trying to boot up the mac, it is NOT detecting any battery and shows up the battery initially in the menu bar with a "X".
in the battery settings, I dont think it detects any battery.
What should be the most likely issue?
in trying to insert the battery board data cable, I broke the top flap of the cable, which I believe protects/covers the actual connector. I have attached a pic of the connector and I did ensure that the lock is in place. Can you help understand if the connector looks OK and inserted enough?
Is dit een goede vraag?
2 opmerkingen
I hope someone answers your question as I have the exact same issue, same ribbon issue same with breaking the cable flap ugh!!! Why the heck would apple make a cable that has to be connected this way!!!
door Kristina M
OK, after ordering the new cable and replacing it, I am now able to detect the battery! yay! thanks to everyone on the forum with your prompt responses!
door Aliasgar P
