Loud noise from inverter air conditioner
There is a loud noise coming from the outdoor unit of the inverter air conditioner. It's like the sound of a hammer drill. It only happens when I turn it on after it has been off for several hours. After that, it works normally, with the usual noise. The temperature is -10 degrees Celsius, and the air conditioner can operate at -15 degrees. What could it be, and can anything be done to fix it?
Below is a video of the noise.
https://youtube.com/shorts/GxowUhyiJ6c
https://youtube.com/shorts/5lpKOXcwoqU
Update (01/15/26)
@oldturkey03 SKYLUX SK-12CDR3DI
Is dit een goede vraag?
2 opmerkingen:
@sergeystad32556 it does sound like your compressor. You may need to open it and listen to exactly pinpoint where the noise is coming from.
door
@oldturkey03 What could be wrong with the compressor, and is it normal to turn it on at all? Can it be fixed? I've only had this air conditioner for a couple of months.
door
Voeg een opmerking toe
