Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Flip Ultra HD is een digitale camcorder van Pure Digital/Cisco, waarvan de productie in 2011 is gestopt.
Change battery and check connections
I found my flip camcorder from 15 years ago. I plugged it in and it did turn on and showed a picture of a battery in the red. For a brief moment, I was able to get the device to start charging. However, when I came back later to look, it said charging paused check battery connection. I plugged it into my computer to see if I could remove my recordings from it. It can’t retain enough charge in order to bring up the data. Can you help me?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
First thing to do is buy a new battery. After 15 years, the original is toast, so I'd frankly be surprised if it worked at all. It takes a specific rechargeable battery pack, but the user manual states you can use either two or three Lithium AAA batteries, depending on exactly which generation yours is.
iFixit doesn't have a guide for the specific repair you want to do, but fortunately the batteries in your camcorder are designed to be replaced by the user. The first three steps of the teardown guide show you how to open it up to access the battery.
Flip Ultra HD Teardown - iFixit
Once you have the battery out, check the spring contacts on top and bottom for any sign of corrosion; you'll need to clean it off if there's any present, then insert new batteries.
Chances are high that will get you fixed up. Be sure to come on back and let us know how it all turns out; that could help the next person who comes along with the same problem.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
hay i found mine after so long there isnt a battery in it any chance you could show what it looks like please :)
door Deel
@colettebalson The Flip Ultra and Flip Ultra HD camcorders take a rechargeable battery pack made by Flip. Here's the manual for it.
Flip Video Rechargeable Battery Pack User Instructions - iFixit
It appears the battery packs are still available from aftermarket sources; a quick search came up with several options on eBay and elsewhere. Here's just one example (not an endorsement).
Battery for Flip Video Camera for sale - eBay
Be sure to check your model number against those supported by the battery, as earlier versions took a 2.4V NiMH battery, while later ones used 3.7V Li-Ion packs or individual AAA lithium batteries.
If you post your model number we may be able to look up the correct specs for yours.
Voeg je antwoord toe
Emily Pilato zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 63
Altijd: 418
