Ga door naar hoofdinhoud
Televisions made by LG.
LG shows no signal
shows no signal even after following instructions other tv's are connected to wifi
Is dit een goede vraag?
1 Opmerking:
What is the make and model number of the TV? Does the TV screen turn on at all?
door
Voeg een opmerking toe
1 Antwoord
Your LG TV displaying "No Signal" typically means the issue is with the current input source (like HDMI from a cable box, gaming console, streaming device, or antenna), not the TV's Wi-Fi connection. Since you mentioned other TVs are connected to Wi-Fi (and presumably working for streaming), and you've already tried some instructions, this points to a problem with the external signal/input rather than internet/apps.
Try a soft reset on the TV: Go to Settings > General > Reset to Initial Settings (this won't delete apps if signed in, but back up if needed).
Was dit antwoord nuttig?
Voeg je antwoord toe
Luci Johnson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 39
Afgelopen 30 dagen: 149
Altijd: 669
