Ga door naar hoofdinhoud
Microsoft's derde generatie Xbox game console, uitgegeven op 22 November 2013.
Disc drive issue, revs then stops
Hi guys, i have an Xbox One which takes a disc in fine, but it tries to spin the disc up, revs for a second then stops, then repeats a few times.
I have tried replacing the laser, i then changed the entire disc drive but still the same issue.
Any ideas what could cause this?
Other than that the xbox works fine
Cheers in advance
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi!
Usually caused by a bad laser, but since you already tried a new one (including a complete new drive), it’s most likely something related to the drive it’s PCB or motherboard.
Did you tried a new SATA cable? Would try this first before you proceed to anything else.
Do blu-ray movies work??
Please let us know how it goes!
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Thanks for your help,
No discs atall, tried a dvd & a game both with the same result.
I will give it a go after work tomorrow, i will swap both cables and see.
Will let you know.
Thanks 👍
door
My pleasure! Alright, please let us know how that goes :)!
Hopefully it will be a simple fix, like the SATA cable.
door
Sadly no improvement, tried changing both cables and also a different power supply. i cant think of anything else to check, thinking its a fault woth the daughter board
door
I’m afraid so. I think it’s the daughterboard… that will be a bummer, because you need the original daughterboard to read games. You can replace it, but this will cause the drive stop reading Xbox games. Only movies will work.
The daughterboard is married with the motherboard with a unique code…
door
Voeg je antwoord toe
Cousinbenson465 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 41
Altijd: 247
