Ga door naar hoofdinhoud
Microsoft's derde generatie Xbox game console, uitgegeven op 22 November 2013.
My Xbox won't update at all even when using my Hotspot
It keeps saying a wifi error code
Is dit een goede vraag?
1 Opmerking
It says system error: E100 00000703 80910006
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi!
It’s just a generic error that it can’t update your Xbox.
When the wifi chip is broken, it can show you the error, the error can also occur if your HDD is broken, or disc drive.
It’s difficult to say…
When you try to cancel the update, does everything work??? Before you did the update, did everything worked correctly?
If yes, I would first replace the HDD and see how that works..
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
I had to put a new cd player in it and I did kinda break a small little pin in the wifi card so it could or the hhd
door
I'll test them in a few days but thank you for the information
door
My pleasure! If something did break on the wifi card, I would replace that one anyway and check if the error is gone. If not, then you might want to check the disk drive or HDD!
door
Voeg je antwoord toe
Casey teska zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 26
Altijd: 162
