Ga door naar hoofdinhoud
Microsoft's derde generatie Xbox game console, uitgegeven op 22 November 2013.
xbox front panel ribbon cable is glitchy and will not power on
I recently tried to get my old xbox out to play some warthunder and it would not turn on, i assumed the ribbon cable was faulty or disconnected as that had happened before but when i reconnected it the "dudu du" startup chime played when the cable was moved slightly no video was displayed and the light shone for a very short time before it turned off. it also made a single ding occasionally after the light and chime. i have no idea what is going on or what i need to move around or buy to fix it. the ribbon cable is definitely working as is the psu.
thanks, Tomi
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi!
Those cables are known to fail and are very fragile.
Are you sure it’s still good? I had to replace those cables many times, as it was still glitching and pressing in every single button at the same time giving the “ding” and “chime” sounds.
Replacing the cable did solved it for me.
Would try this first and see how that works out!
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Big time agree with this. I had issues with my own Xbox with that cable after I did some internal cleaning. They are known to be really touchy and prone to failure.
door
Voeg je antwoord toe
Tomi bell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 115
