Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Lenovo G510 is een laptop ontworpen door Lenovo en uitgebracht in 2014 als onderdeel van de G-serie Ideapad-laptops van Lenovo.
laptop won't turn on and won't charge
Is dit een goede vraag?
2 opmerkingen
Have you noticed something strange before it happent? Maybe slow/very fast charge or something like that?
door Deel
i don't remember it just stopped
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
@mohamedkha39364 start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
Next you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see.
It is also possible that this is a bad RAM module or a bad LCD. So remove the RAM, clean the contacts with a pencil eraser. Do it gentle so as to not destroy the module. Replace it and restart. If you have more than one module, remove it and just leave one connected.
You may also have to consider replacing the battery. A depleted battery can no longer be charged. However, it should not prevent your computer from coming on, if it is connected to the AC adapter.
Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Mohamed Khaled zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 24
Altijd: 210
