Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatiehandleidingen en tutorials voor E-Scooters.
My e-scooter starts but doesnt move and E6 appears on screen.
I have a Ducati Pro || Plus. It starts doesnt move and E6 is lighting on the screen.What do I do?
Is dit een goede vraag?
Score 1
4 opmerkingen
On most Ducati and similar MT Distribution e-scooters (including Pro-II, Pro-II Evo, and Plus), E6 typically means a throttle or controller communication error — basically, the scooter’s control unit is not receiving correct data from the throttle or the motor hall sensors.
door Deel
How to get your electric scooter out of E6
door Deel
Check the wire going into the motor isn’t damaged.
door Deel
Hey I have a x9 electric scooter and I was riding it tonight and I notice the E6 code show up the bike tuning on but not moving, how can you help me here.
door Deel
Voeg een opmerking toe
3 Antwoorden
Filteren op:
Het nuttigste antwoord
  • Turn off the scooter completely. Wait 1–2 minutes. Turn it back on and check if E6 disappears. Sometimes, temporary communication errors clear this way.
  • Check the Throttle Cable and Inspect the Motor Cable
  • Reset (Factory Reset if possible)
Was dit antwoord nuttig?
Score 1
Slacken off the nuts on the motor wheel and take the wheel out. Check the cable hasn't twisted and torn. These scooters need the wheel nuts checked for torque once in a while as sometimes the axle will rotate pulling the cable and breaking wires.
Score 1
Two things to split before you buy any part.
1) Data fault or dead throttle? On most of these (Ducati/MT Distribution, and the Kugoo/VSETT/Boyueda family with the 6-pin TF-100 grip) the throttle and the screen are one unit talking to the controller over a serial line. E6 on those means the controller stopped hearing the throttle, not that the pack is flat. Test: key on, twist. If the screen does not change and the throttle feels dead, it is wiring or the throttle unit. If it beeps/clicks and the wheel still does not turn, look at the controller output and the motor phase.
2) Then measure instead of guessing. Meter the pack at rest, then again with the rear wheel off the ground and the throttle held. A 36V pack reads about 42.0V full, a 48V pack about 54.6V. If it drops more than 3-4V under load and does not come back, that is the pack, and no throttle will fix it. If it holds and you still get E6, it is the harness.
Cheap order, before controllers:
- Unplug the throttle at the stem (6-pin black or 5-pin green Julet), look for a pushed-back pin, green corrosion, or a pin that wiggles. Reseat it.
- Check the cable where it passes the folding joint and the stem clamp. That is where strands break. Nige56 is right about the motor-side cable and the axle torque too; check both ends.
- Only then settings, and only then parts.
A dead throttle with a working screen on these almost never means "replace the controller". More of them get fixed by one pushed-back connector pin than by any board swap.
Voeg je antwoord toe
Maxim Armin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 116
Altijd: 1,528
