Ga door naar hoofdinhoud
Microsoft's derde generatie Xbox game console, uitgegeven op 22 November 2013.
I did a factory reset on my xbox one as had the black screen
it worked for a while then i had the black screen again so did the factory reset again it worked for a while then would take ages to load the home screen but had no pictures and couldn't select anything or get the settings up whats the cause of this and how can i fix it
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Hi Timmy!
I would replace the HDD and see how that goes. It does sound like you are having issues with the harddisk.
Guide: Xbox One Hard Drive Replacement - iFixit Repair Guide
After this, you do need to put the software on first, before you replace it.
Here is a guide regarding how to do this: Install firmware on Xbox One S - iFixit Repair Guide
Please let us know how it goes!
Xbox One Harde schijf Afbeelding
Handleiding
Xbox One Vervanging van de harde schijf
Moeilijkheid:
Gemiddeld
45 minutes
Xbox One S Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
30 minutes - 1 hour
Was dit antwoord nuttig?
i agree with koppie.
you can also remove the hdd and plug it into your pc using a hdd reader, wipe it completely and reinstall the ous file, that's a whole process tho and can be finicky. I would just get a new hd (solid-state for quicker loading times) and replace the existing drive. You will most likely need a pc and a hdd reader with a usb3.0 connection to properly format the new drive and a usb3.0 thumbdrive/flash drive (also properly formatted) to install the OUS firmware
Voeg je antwoord toe
timmy davies zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 23
Altijd: 157
