Ga door naar hoofdinhoud
De 11" iPad Pro van de tweede generatie werd uitgebracht in maart 2020 met de modelnummers A2228, A2068, A2230 en A2231.
After replacing the battery, screen has become partially discolored.
As the title, after I replace the battery (and usb-c-port), screen get partially discolored. I didn't change any parts than these above two.
Afbeelding
(right upper part when horizontalized).
Is there a easy way to fix this? If not (how to buy new lcd or display), I give up ...
Is dit een goede vraag?
3 opmerkingen
I used IPA to cleanse frame and behind display. Is there a possibility that made signinficant part ruin?
door
I don’t know the reason, the discolor disappeared in a few days.
door
@tpzvrxeb1qqmq5l Almost certainly some alcohol got under the display and eventually evaporated. Your screen should be fine now.
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
It definitely looks like liquid contamination on the screen. The good news about IPA (at least at higher concentrations, like 90% or higher) is that it doesn't leave behind residue, so with luck it should eventually evaporate out of the screen. I'd give it a few days, keeping an eye on it to see if it looks like it's getting smaller. You may be able to hasten that by heating it with a hair dryer; blow on it for three minutes or so, let it cool and repeat a few times.
If you've given it plenty of time and it doesn't improve then it may indeed be damaged, in which case you'll have to decide whether you can live with it as is or go to the trouble and expense of replacing the screen.
Was dit antwoord nuttig?
Score 2
Hey,
I'm personally not sure if there is a way to fix it as I dont have experience with ipads personally. However if you do end up needing/wanting to replace the screen. I have found links that may help you. Hopefully someone else can assist you better with this issue.
Good luck,
Here is a link for a repair guide.
iPad Pro 11" 2e generatie schermvervanging
I also have a link for a screen however as I live in Australia it is an Australian online store.
https://www.polartech.com.au/products/af...
Score 1
Voeg je antwoord toe
S K zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 188
