Ga door naar hoofdinhoud
Clamp force is basically gone how do I restore it
So basically what happened was i had this headphones pretty great then a careless big headed relative wore it their head pretty big compared to my small headphones that fit mine perfectly now it slides and stuff and doesnt clutch my head at all any way to restore it to its original clutch?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
If you try this you do run the risk of cracking the plastic of the headband, braking your headphones
but..
Very gently, using very light pressure, you can try to bend the headband back into position.
You will want to hold above the ear cups, to avoid stressing the plastic swivel connecting the ear cups to the headband, and bend inwards only until you start to feel the resistance increase, try them on and see if it has improved.
Continue this slowly, repeating this until it has a bit more clamping force.
Was dit antwoord nuttig?
Voeg je antwoord toe
Kayra zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 42
Altijd: 310
