Ga door naar hoofdinhoud
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
437 Vragen Bekijk alle
Do you think it is fixable?
I found a great deal on a MacBook Pro 2.5 Quad i7 from a friend for $400, only it is water damaged. I can repair almost any Apple problem easily but I hate water damage. The computer boots every time and charges the battery but will only display on an external monitor. When on an external monitor everything works and it runs with out a hitch. The screen stays completely black during this whole time with no backlight but briefly flashes the screen every time it is turned on. I haven't been able to look inside but my question is, does anyone think that i can just clean off the board and LVDS contacts and maybe replace the lcd cable and have to and have it work. Could anything be completely destroyed on the logic board. I have fixed several iPhones that have been submerged in the past but never a computer. Do you think i can fix it?
Is dit een goede vraag?
Commentaar:
if you wish to sell this i will pay 500$ for this as same in problem now. i m also crazy about these products. you can sell it on ebay thnx
door
if you ready to sell you then tell me the item number thnx
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Since it appears that only the internal display is not working I think it's fixable - but it could be a costly repair. See this similar Question.
If this Answer is helpful please remember to return and mark it Accepted.
Was dit antwoord nuttig?
Score 1
Commentaar:
Thank you machead3, I read the question you gave me the link to and then got my friend to check to see if the capacitor was still there and it was so I'm getting the mac and I will try and fix it.
door
Here is a link to the ifixit water damage guide and a link to the tear down for your unit. Good luck.
Electronics Water Damage
MacBook Pro 15" Unibody Late 2011
Score 1
Voeg je antwoord toe
Owen Cunneely zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 763
