Ga door naar hoofdinhoud
Repair guides, support, and troubleshooting information for MacBook Air models with 11-inch displays.
929 Vragen Bekijk alle
MacBook Air hard drive compatibility (A1304 to A1237)
I have a MacBook air that came with the A1304 hard drive. I have an A1237 replacement drive. They have different connectors (you can see the pictures at the bottom of this page.
Can I just buy the A1237 connector and use the A1237 drive in a macbook that came with an A1304 drive?
Thanks!
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Unfortunately, no. I took a moment to compare the two hard drive cables from these models and the logic board connector ends are not the same. So, the hard drive cable that will fit into the A1237 drive will not fit the logic board of the A1304.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
More over, A1237 is a kind of PATA drive but A1304 is a SATA.
door
Voeg je antwoord toe
brad zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,292
