Ga door naar hoofdinhoud
Dell Inspiron 531s desktop computer.
16 Vragen Bekijk alle
Asking for XP recovery disk
Error: syst./32/drivers\PCI.Si
Asking: PROFESSIONAL PAK 2-CD SPCMDCON.SYS FILE NEEDED
ERROR: LOADING OPERATIONS SYST POSSIBLE FULL/DAMAGE DISK
I have the disk to restore in case the computer crashes,, but when I put this in the above message comes up.
Is there a link where I can put onto CD rom ( Blank) where I can burn onto?
I am so frustrated with this. Please help advise,
Thank-you
i
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
linda339802003, try this from here and the Dell manual :" NOTICE: Using Dell PC Restore or Dell Factory Image Restore permanently deletes all data on the hard drive and removes any programs or drivers installed after you received your computer. If possible, back up the data before using these options. Use PC Restore or Dell Factory Image Restore only if System Restore did not resolve your operating system problem. NOTE: Dell PC Restore by Symantec and Dell Factory Image Restore may not be available in certain countries or on certain computers.
Use Dell PC Restore (Windows XP) or Dell Factory Image Restore (Windows Vista) only as the last method to restore your operating system. These options restore your hard drive to the operating state it was in when you purchased the computer. Any programs or files added since you received your computer—including data files—are permanently deleted from the hard drive. Data files include documents, spreadsheets, e-mail messages, digital photos, music files, and so on. If possible, back up all data before using PC Restore and Dell Factory Image Restore.
Windows XP: Dell PC Restore
Turn on the computer.
During the boot process, a blue bar with www.dell.com appears at the top of the screen.
Immediately upon seeing the blue bar, press <Ctrl><F11>.
If you do not press <Ctrl><F11> in time, let the computer finish starting, and then restart the computer again.
NOTICE: If you do not want to proceed with PC Restore, click Reboot in the following step.
<LI value=3>On the next screen that appears, click Restore.
On the next screen, click Confirm.
The restore process takes approximately 6–10 minutes to complete.
When prompted, click Finish to reboot the computer.
NOTE: Do not manually shut down the computer. Click Finish and let the computer completely reboot.
When prompted, click Yes.
The computer restarts. Because the computer is restored to its original operating state, the screens that appear, such as the End User License Agreement, are the same ones that appeared the first time the computer was turned on.
Click Next.
The System Restore screen appears and the computer restarts.
After the computer restarts, click OK.
Windows Vista: Dell Factory Image Restore
<LI value=1>Turn on the computer. When the Dell logo appears, press <F8> several times to access the Vista Advanced Boot Options Window.
Select Repair Your Computer.
The System Recovery Options window appears.
<LI value=3>Select a keyboard layout and click Next.
<LI value=4>To access the recovery options, log on as a local user. To access the command prompt, type administrator in the User name field, then click OK.
Click Dell Factory Image Restore.
NOTE: Depending upon your configuration, you may need to select Dell Factory Tools, then Dell Factory Image Restore.
The Dell Factory Image Restore welcome screen appears.
Click Next.
The Confirm Data Deletion screen appears.
NOTICE: If you do not want to proceed with Factory Image Restore, click Cancel.
Click the checkbox to confirm that you want to continue reformatting the hard drive and restoring the system software to the factory condition, then click Next.
The restore process begins and may take five or more minutes to complete.
A message appears when the operating system and factory-installed applications have been restored to factory condition.
Click Finish to reboot the system.
Removing Dell PC Restore
NOTICE: '''Removing Dell PC Restore from the hard drive permanently deletes the PC Restore utility from your computer. After you have removed Dell PC Restore, you will not be able to use it to restore your computer's operating system.
Dell PC Restore enables you to restore your hard drive to the operating state it was in when you purchased your computer. It is recommended that you do not remove PC Restore from your computer,''' even to gain additional hard-drive space. If you remove PC Restore from the hard drive, you cannot ever recall it, and you will never be able to use PC Restore to return your computer's operating system to its original state.
To remove PC Restore:
<LI value=1>Log on to the computer as a local administrator.
<LI value=2>In Windows Explorer, go to c:\dell\utilities\DSR.
Double-click the filename DSRIRRemv2.exe.
NOTE: If you do not log on as a local administrator, a message appears stating that you must log on as administrator. Click Quit, and then log on as a local administrator. NOTE: If the partition for PC Restore does not exist on your computer's hard drive, a message appears stating that the partition was not found. Click Quit; there is no partition to delete.
<LI value=4>Click OK to remove the PC Restore partition on the hard drive.
Click Yes when a confirmation message appears.
The PC Restore partition is deleted and the newly available disk space is added to the free space allocation on the hard drive.
<LI value=6>Right-click Local Disk (C) in Windows Explorer, click Properties, and verify that the additional disk space is available as indicated by the increased value for Free Space.
<LI value=7>Click Finish to close the PC Restore Removal window.
Restart the computer.
Hope this helps, good luck.
Was dit antwoord nuttig?
Score 3
but when I do the f8 it takes me to the keyboard login but only the "Other User" one shows up and I left mine password free but it says "the specified either does not exist or could not be contacted"
Update
I'm sorry it took so long to resond but my phone/internet has been off sence last weekend *all part of the boondock adventure* No, not the same but I do want to do the factory recovery with F8 but I can't because it takes me to a 'other User" logon I don't have the cd/dvd's to install manually and my cd drive is broke, but I do have a USB flash drive/ thumb drive *if they are the same* Thanks Again.
1 Opmerking:
donna, do you have the same problem as the OP
door
Try going to fixerrorkit.com. this looked like it has a Microsoft fix.I've used Microsoft's fixs in the past. They seem to help. See what you think.
When you get on web site fix error.com do a search on that web site as follows "spcmcon.sys not found or missing"
That should get you to the Microsoft fix download.
Voeg je antwoord toe
linda339802003 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,810
