How can I connect my starting motor
Bought my first car but came with the cables uninstalled, it's year 89 and I don't know why but I think I'm doing it wrong because the starter just sounds but the Bendix doesn't come out
Is dit een goede vraag?
If your 1989 Buick Century’s starter motor spins but the Bendix gear (the part that engages the flywheel) doesn’t pop out, you're likely facing one or more of the following issues—especially since the starter cables were disconnected when you got the car.
Let’s go step by step:
Your starter motor has two or three terminals:
Correct wiring:
📌 Make sure the ground strap from engine to chassis is intact!
If your wiring is correct and:
Component Check Battery voltage 12.6V+ at rest Starter wiring Big cable to large post, purple wire to S terminal Engine ground strap Tight, clean contact Starter mounting Bolted firmly to engine Solenoid action Clicking and pushing Bendix gear forward Flywheel Not damaged or missing teeth (remove starter to see)
Was dit antwoord nuttig?
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 44
Altijd: 193
