Whirlpool 1cwtw4845ew1 toploader engaging lid lock non-stop
Whirlpool washing machine 1cwtw4845ew1 was in the middle of the washing cycle when it started engaging and disengaging the lid lock randomly, and now it won't do anything else anymore. Tried reset as per a Youttube video, but the lid lock keeps on clicking non-stop when the machine is plugged in.
Is dit een goede vraag?
5 opmerkingen
Thank you so much! I followed the steps on the tech guide and now everything works just fine! I believe this was a software error as I did the manual check for lid lock once, it reported no errors but after that everything worked as usual.
door josh2203
The strangest thing, it was fine for a couple of days, now does the same. I will do the rest of the tests at page 18 if it continues, but I'm fearing the control board might be going bad?
door josh2203
@josh2203
Run the complete diagnostics test just to make sure that it isn't something else that is causing the problem and a clicking lid lock is just the symptom that's showing
door jayeff
Running the calibration fixed the problem until now. Currently, I'm baffled, the washing machine does calibration perfectly, as well as automatic test cycle, but when it stops, done and lid lock stay illuminated and stuck. When no leds are lit, the lid lock engages and disengages randomly and normal washing cycle refuses to start, but as said, it performs all the functions perfectly in calibration and auto test mode. Any tips? Thanks very much!
door josh2203
New lid lock solved the issue. Thanks!
door josh2203
