Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatie- en demontage-informatie voor Samsung's vlaggenschip S21 Ultra Android-smartphone, uitgebracht in januari 2021. Ook bekend als de Samsung SM-G998U1
Recently replaced my battery, now the screen glitches regularly.
Two weeks ago I replaced the battery of my S21 Ultra according to the ifixit guide. When pulling the battery off with the suction cup, quite a bit of force/violence was still needed, but otherwise it went fine. The phone seemed to work fine for the first few days after that.
After 4 days, however, the screen started to flicker, artifacts and lines appeared on the screen and the screen went completely black. Since then, this has been happening more and more often, I often solve it by pressing volume down + power for a few seconds, after which the phone restarts. Unfortunately, this does not always work and sometimes I am without a usable phone for hours, and it has also been happening more and more often over the past week.
I suspect that I accidentally damaged the display cable during the battery replacement, but when I opened it again I saw no visible damage. Then I immediately disconnected all other connections again, checked for dirt and reconnected them..
Before I buy a new screen (the cable is attached to this model) I was wondering if there are other ways to be sure that this is the cause. Or could it still be something else?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
You're thinking in the right direction — based on your description, the display flex cable or its connector on the board is the most likely culprit, even if there’s no visible damage.
Let’s break it down:
  • Started days after repair → likely physical strain, not ESD or battery quality
  • Flickering, artifacts, lines, and then black screen
  • Temporary fix via volume down + power (force reboot), suggesting the display logic resets briefly
  • Worsening over time → points toward progressive failure (like a weakened or intermittently broken trace or connector)
🔍 Most likely causes:
1. Partially damaged display flex cable
  • This cable routes under or near the battery, and force during removal (especially if adhesive was stubborn) may have creased or micro-torn it.
  • These microfractures may not be visible, but can worsen with heat or flexing.
  • Since the S21 Ultra display and digitizer are one unit, the cable is non-removable and part of the screen assembly.
2. Loose or improperly seated connector
  • Even if it looks clicked in, a slightly angled or dirty connector can create intermittent contact.
  • Thermal expansion (device heating) can worsen this.
3. Damaged connector or solder joints on motherboard
  • Less common, but if the battery tool pushed or lifted against the socket, it could have lifted a pad or cracked a solder joint.
  • Hard to detect visually.
🛠️ Steps to diagnose before buying a new screen:
A. Open the phone again (safely), and do:
1. Inspect connector under magnification
  • Use a loupe or macro lens: look for bent pins, dark spots, lifted solder pads on the display socket.
2. Clean connectors
  • Use 99% isopropyl alcohol and a soft brush to clean both the flex contacts and the motherboard connector.
  • Compressed air can also help remove micro debris.
3. Reconnect carefully
  • Make sure the connector clicks in perfectly flat and seated fully.
  • Tape it down gently to reduce movement.
B. Heat/pressure test
While the phone is open, gently press or wiggle the flex cable while powered on:
  • If display glitches/flickers → you confirmed it’s the cable or connector.
  • If nothing changes → damage could be inside the flex (not externally visible).
🧪 Want to go deeper?
If you have access to tools:
  • Use a thermal camera to check if heat buildup coincides with glitches.
  • Try Samsung’s hardware diagnostics (via Samsung Members app or dialing #0#) when screen works — if it fails the display test, it often points to a hardware issue.
🎯 Final thoughts:
If:
  • You've ruled out dirt and seating issues
  • You've tested pressure/flex sensitivity
  • Problems worsen or occur with heat or movement
Then it’s almost certainly the display flex cable — and on the S21 Ultra, that means a new screen assembly is required. 😔
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thanks for the response! I didn't think to try heat the flex cable. That's a good suggestion for any future repairs (hopefully not on this phone).
I decided to bite the bullet and ordered a new screen, installed it and it did fix all the issues. (it's been a little over a week now)
Thanks again 😊
door Deel
I don't think this ChatGPT response is accurate here. I think it's the same as here: https://de.ifixit.com/Antworten/Ansehen/...
Did you use a lot of isopropanol? That was the issue for me. I replaced the battery in my S21, let the isopropanol dry a bit, and everything seemed fined. The next morning however, the fingerprint scanner wasn't recognized anymore, and the next night, the screen went black. I disassembled the whole thing and after a couple days of drying, it started working again, both the screen and the scanner! However, I tried to re-assemble and power it on multiple times, only the third time or so it worked perfectly again. Hopefully it stays that way
door Deel
Voeg je antwoord toe
Sander Everaers zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 26
Altijd: 320
