Ga door naar hoofdinhoud
Repair guides and support for the Willys-Overland CJ-3A "Civilian Jeep," manufactured from 1949-1953.
1 Vragen Bekijk alle
Why wont my jeep start
points and condenser have been replaced the coil too but when turning over there iis no fire power to the coil
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Susan Luntsford, you did not tell us if it is stock or if it is a mod jeep. Engine Size and mods are important since it does make a difference. If you have no power to the coil, check your ignition switch. Make sure the switch close the circuit to the ignition coil. Check the wiring from the positive terminal of the battery to the switch, make sure it is connected and not shortened out. If it worked before, but stopped working since you replaced the parts, double check your work.
Was dit antwoord nuttig?
Score 4
Voeg je antwoord toe
Susan Luntsford zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 3,099
