Ga door naar hoofdinhoud
Processor: 13th Generation Intel® Core™ i5-13450HX Processor Operating System: Windows 11 Home Single Language 64 Graphic Card: NVIDIA® GeForce RTX™ 3050 Laptop GPU 6GB GDDR6 Memory: 8 GB DDR5-4800MT/s (SODIMM) Storage: 512 GB SSD M.2 2242 PCIe Gen4 QLC Display: 15.6" FHD (1920 x 1080), IPS, Anti-Glare, Non-Touch, 100%sRGB, 300 nits, 144Hz Battery: 4 Cell Rechargeable Li-ion 60Wh AC Adapter and Power Supply icon: 170W Slim 3pin AC Adapter - US
How do I clean the fans?
My LOQ 15IRX9 fans haven't been cleaned since it was bought, and I can see some dust building up on its bottom cover. I want to know how I can clean the fans on the inside by myself. How do I do it properly?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @kialzi
Here's the hardware maintenance manual for the laptop.
Go to p.42 in the manual (48 of 68 pdf) to view the procedure to remove/replace the thermal module.
Once it's removed this will allow you gently clean the fans away from the other components inside the laptop.
Also once it has been removed, check the condition of the thermal paste on both the CPU and the GPU to make sure that it hasn't dried out and needs to be refreshed.
Here's the ifixit Aanbrengen van koelpasta guide that may help with this.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Kialzi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 14
