Ga door naar hoofdinhoud
The Kindle Fire, Fire, or Amazon Fire is an Android-based media tablet by Amazon with a multi-touch color display. Repair requires only screwdrivers and prying tools.
when turning device, letters will not rotate with it.
I can only read my Kindle Fire in the short stubby side.
will not allow me read in any other position. I have allowed the battery to go totally dead before recharging, thinking this might solve problem. But alas It didn't help.
It's frozen in one position. How do I clear this up. It is only 2mo.old.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
marlene johnson, try to tap on the Settings icon (looks like a gear) in the top right corner of the screen. You should see where you can lock and unlock the screen position. More on that on here, hope this helps, good luck.
Was dit antwoord nuttig?
Score 5
6 opmerkingen:
Thanks! This helped me too.
door
you are welcome:)
door
Thank you. This was the answer to my problem.
door
you are welcome ;-)
door
Thank you ,You help me fix my kindle ;)
door
1 commentaar meer tonen
Voeg je antwoord toe
marlene johnson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,308
