Ga door naar hoofdinhoud
Lenovo Yoga Smart Tab tablet was launched on 5th September 2019. The tablet comes with a 10.10-inch touchscreen display offering a resolution of 1920x1200 pixels.
My lenovo tablet keep turning on and off when I turn it on
Someone pls help me i have been on the same problem for years and its always red when I charge it
Is dit een goede vraag?
2 opmerkingen
Hi @voltuz
Please confirm the model number of your table i.e. is it a YT-X750 or an YT-X705 model as there's not much information regarding the YT-X750?
door
@jayeff it's YT_X705 Sorry about that
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @voltuz
No problems ;-)
Does it also turn on and off when the charger is connected?
If it doesn't, the only thing that I can suggest is that you replace the battery.
Here's a teardown video that may help.
The battery can be seen at 9:52 minutes into the video.
Unfortunately the parts list doesn't show the battery in the list of parts (click on Select Commodity to see the parts list).
I think that the battery model number is L19D2P32 so if you decide to replace the battery search online for the battery model number to find suppliers that suit you best. The model number should be printed on the battery if you wish to verify that it is the correct one before ordering.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
It also turn on and off while charging
door
@voltuz
It could also do this if the battery is faulty.
I think that it's either a faulty battery or a faulty charging circuit on the systemboard.
The easiest option is to change the battery as you would need the schematic and boardview diagrams for the systemboard to find out which components (and the type/value/location in case one is faulty) are associated with the charging circuit if the battery is OK. I can't find either diagram them online
door
@jayeff Ok thanks!
door
Voeg je antwoord toe
Voltuz zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 189
