Ga door naar hoofdinhoud
How do I install a HDD SSD Connector on my Lenovo IdeaPad 130-14IKB?
In context 6 months ago I took my laptop and put it in a cabinet then slept, next thing I know the Hard disk wasn't detected. I went to other repairshops and they said it would be expensive, but I did my own research and found parts that is compatible with the motherboard of my laptop. I would like to know how I can remove the old one and replace it with the next one without damaging the motherboard.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi @gigahendrix
Do you want to replace the HDD or the HDD connector board?
Here's the hardware maintenance manual for the model series.
Go to p.36 (40 of 74 pdf) to view the procedure to remove the HDD (or SSD). Once it has been disconnected from the HDD connector board, you can disconnect the board from the motherboard.
If the board needs replacing on p.67 Item #12 you'll find the Lenovo part number for the board. Search online for 5C50R34852 to find suppliers that suit you best. (supplier examples only)
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Giga Hendrix zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 26
Altijd: 165
