Ga door naar hoofdinhoud
Reparatie- en demontage-informatie voor versterkers in audiosystemen.
Amplifier output working but can't hear music why?
Amplifier lights and modes and Bluetooth connection everything is working without sound
Is dit een goede vraag?
1 Opmerking:
@mahadevan98771 what make and model is your Amp? What have you checked and what have you tried?
door
Voeg een opmerking toe
1 Antwoord
If your amplifier is showing lights and modes and the Bluetooth connection is working but you're not hearing any sound, here are some things to check:
1. Check Speaker Connections
  • Ensure your speakers are securely connected to the amplifier. Double-check both the speaker wires and the connections on the amp.
2. Verify Volume and Mute Settings
  • Make sure the volume is turned up on both the amplifier and the connected device.
  • Check that the amplifier isn’t muted. There may be a mute button or setting you need to turn off.
3. Input Source Selection
  • Ensure the amplifier is set to the correct input source (Bluetooth, aux, etc.). If the wrong source is selected, it won’t output sound.
4. Test with Different Audio Source
  • Try a different audio input source (like using an aux cable or another Bluetooth device) to see if the issue is with the current source.
5. Check Audio Settings on the Connected Device
  • Ensure your connected device (phone, PC, etc.) is set to output audio to the amplifier.
  • If using Bluetooth, confirm that audio output is set to the Bluetooth device.
6. Amplifier Settings
  • Some amplifiers have settings or modes that might mute or reduce sound, like low-pass filters or special modes. Double-check the amplifier’s manual to make sure nothing like that is active.
7. Internal Amplifier Issue
  • If nothing else works, the issue might be internal, such as a faulty amplifier board or power supply. You may need professional repair in that case.
It would also help to know the model of your amplifier to provide more specific troubleshooting steps. Let me know if any of these suggestions help!
Was dit antwoord nuttig?
Voeg je antwoord toe
Mahadevan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 169
