Ga door naar hoofdinhoud
Powers on then off immediately, bad PSU?
Ok I have a imac a1145 that I bought broken, and initially it would turn on randomly and sometimes the fans would speed up to max rpm. So I took out the logic board and noticed 2 6.3v 1500uf bad caps. I replaced them with good ones, but now the imac will turn on for a split second and turn back off. I noticed on the logic board that the #1 green led indicator is on once the power cord is plugged in and #4 red led indicator turns on after I try to start it. I have looked online for what they mean and have gathered that the #1 is tricky voltage (that's vague), and #4 is overheating. Is the #1 indicator specifically for the PSU or does it cover the logic board too? Any ideas or suggestions would be great, I am at my wits end with it and really don't want to start buying unnecessary parts. Thanks for the help.
Is dit een goede vraag?
Score 1
2 opmerkingen
Yeah I'm sure, the striped side is negative and the board is clearly labeled with a + sign for positive. The only thing I can think is that I did not replace the caps with the same physical sized caps. One fits standing as it should and the other I laid on its side and ran wires from the legs to the board. I don't see how that would be an issue but maybe I'm wrong. I did have a bit of trouble getting the one that is standing properly to go back in the holes, so maybe I damaged the cap.
door
Ok so I replaced the 2 caps again with known good ones, and now it acts a little better when trying to turn on, whereas before it wouldn't always flash the white led and now it always turns the white led on every time but I still got that #4 indicator light on. Is it possible to have a cold joint on either the GPU or CPU causing this? If so would reflowing them with my hot air work station fix it?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Here is a link to a previous post with the guide to what the lights mean. From what you describe I wonder if you don't still have one or more bad caps. Are you certain you installed the new caps with the correct polarity? Good luck
Where is a decoder for diagnostic LED pattern?
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Erick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,789
