My RX10 will not turn on
My Sony RX 10 even with a new battery will not turn on
Is dit een goede vraag?
@john76955 could be a DC-DC board issue. I would suggest that you check the voltage on your SY1027 board and check the F1 fuse while you are there. That is the same board that holds the RTC battery (replace that as well).
If you have power on that than you know that your battery terminal is good and the board gets power, Then you would need to proceed to the DC-DC converter and the power control IC. Luckily you can download the LVL 2 and 3 SM for your camera from this page Sony Cyber-shot DSC-RX10 under the Documents Heading. Those manuals will help you to disassemble your camera and to check things out. Once you are at a point where you can check those things, post some good pictures of our boards etc. with your Question, here is the guide for that Voeg afbeeldingen toe aan een bestaande vraag That way we can see what you see.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 24
Altijd: 309
