Ga door naar hoofdinhoud
Apple's top-of-the-line smartphone for 2020. Announced on October 13th and released November 13th, the iPhone 12 Pro Max sports a 6.7" OLED display, a triple rear camera system with LiDAR, and 5G connectivity. Successor to the iPhone 11 Pro Max.
New battery, screen now only shows two green lines. iPhone 12 Pro Max.
Got battery and kit from iFixit, innards didn't match what was shown. I replaced the battery and the phone chimes when it's powered but the screen only shows two green lines in the lower left corner with some touch sensitivity -- that's all! It worked fine when I took it apart. Help! I'm a technically competent experienced 84 yr old person.
Is dit een goede vraag?
2 opmerkingen
@oldturkey03 nat2 has another question regarding the difference in appearance; I've suggested that the display has separated from the screen frame.
your instructions for repair of my iPhone 12 Pro Max don't match what
door
@dadibrokeit now that makes sense. Thank you for clarifying.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Unfortunately my experience with a screen coming apart from the frame like yours did was not encouraging. Once the OLED had been separated it came up with serious display issues and I ended up having to replace the screen.
My suspicion is that the frame also serves the purpose of protecting the delicate connections from the motherboard to the circuits etched into the glass, and the pressure of the opening tool damages those connections causing the kind of problems you're seeing.
Sorry to say I'm fairly sure you're going to need a new screen.
P.S., yes, I do get notifications when you tag my username. It's been a busy day patching a kid-size hole in the sheetrock at my son's house. Yeah, don't ask.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
nat2 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 52
