Ga door naar hoofdinhoud
Informatie over reparatie, demontage en probleemoplossing voor de 13-inch 6e generatie Apple iPad Air met M2-chip. Uitgebracht in mei 2024 naast het 11-inch model.
Where is the processor located on the iPad?
Where is the processor located in the iPad? What is the physical location of the processor? And is there a diagram of the device?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Did you review the iFixit Teardown? iPad 6 Demontage jump to Step 8 to ID the chips.
Technically there is no CPU chip, just like the iPhones and other iPad models they all use a SoC architecture which unlike a PC or older Mac which used Intel CPU’s and needed a lot of other support chips these support chips are all integrated into the SoC chip. Hence why it’s called a System on Chip architecture. These chips all have the designation A_ where blank in a number, within the newer Mac systems Apple has also moved to a SoC architecture with the designation M_ with the blank again being a number.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
Here's the picture you're looking for.
Afbeelding
The Apple A10 Fusion APL1W24 SoC processor is outlined in red in this picture, but you won't be able to see it when you open up the iPad because it's underneath a metal shield covering the motherboard. You can see the shield in this picture.
Afbeelding
Score 1
Voeg je antwoord toe
Yeonatan Belmas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 68
Altijd: 1,117
