Ga door naar hoofdinhoud
Microsoft's derde generatie Xbox game console, uitgegeven op 22 November 2013.
Xbox one won't power on, no light or sound on power button. Good PS
Got an xbox one from a friend. Hadn't powered on in a while. Turned it on and it locked up at the green xbox screen. Booted into safe mode, and started factory reset, but it locked up again. Attempted reboot, but now I get no sound or light on the power button. Using a known good power supply. Hard reset (holding power button for 10 seconds) does nothing. Any ideas?
Is dit een goede vraag?
Score 1
2 opmerkingen
What color is the light on the power supply?
door
Solid orange. It is a working power supply. I have another xbox one that is fine, and the power supply is from it. I have hooked that back up and it works fine. Issue is not the power supply, as I stated above.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
This might be a bit of a long shot, but it could be an issue with the RF Module Board. You could try to reseat or replace the board and see if that makes a difference. Otherwise, it's probably an issue with the motherboard itself.
Replace a damaged RF module daughter board. This part is compatible with an Xbox One console. Afbeelding
Product
Xbox One RF Module Board
$5.99
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Ben “Benny2beer” Schneider zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 10
Altijd: 77
